cobra 29 help
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
I was given an old cobra 29 and when I hooked it up I could transmit but not receive. i tried with an external speaker and still nothing. the meter doesn't work so i can't use that to tell if its receiving and not working making sounds or not even receiving.
also there is a knob wired in on the inside of the radio, electrical taped in. what is it?
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Couldn't even begin to tell you without at the very minimum a pic of where it's wired into the radio... Maybe it's a power output control (Dial-A-Watt), maybe a talkback volume, could be a control for a noisemaker of some sort, could be anything really (it's not something that was there originally).
Do you have any CB or 2-way radio shops in your area? I would think someone there could help you figure out what's wrong with it (maybe repairing the radio's receive circuit if necessary).
