Cmp removed without noting position of shaft, how can I get it put back in properly?
96POSRANGER4X4
Easy1212
Ranger 4x4
Pulled the cmp shaft out, didn't pay attention to it's position and put it back in incorrectly. Thought my firing order was wrong when I tried to start it but not the case. Has to be that darn cmp shaft. Can any one tell me how to get it back in correctly? I don't want to have to guess at it...
Get cylinder 1 to TDC compression, then put the sycnro in so that the vane is centered in the window.
Rearanger
23
Southeast USA
Good demo HERE Also be sure to view the follow up video link on the same page.
96POSRANGER4X4
Easy1212
Ranger 4x4
Ahh, that sounds simple enough . Trying that when I get home, I read some other posts that made it sound like mission impossible.
96POSRANGER4X4
Easy1212
Ranger 4x4
Ok so I'm a bit confused, I bought a new synchro because the old one was not in good shape. It came with an install tool, but the "vane" is not centered in the window when I use it. It is 1\4 turn before the window. I installed it this way but the truck would not start. I'm thinking the vane need to be in the window like you said at tdc so do I install it without the install tool and try to get it to stay in the window somehow?
96POSRANGER4X4
Easy1212
Ranger 4x4
Ok so I re did the synchro, with the install tool and got it started but it is running rough abd backfiring thru the intake it sounds like. The paper that came with the cam synchro implied that the unit should be at a particular degree but didn't list a degree for my part number of course, I currently have it at 0 degree
96POSRANGER4X4
Easy1212
Ranger 4x4
I think I still have one somewhere, I didn't think of that. Been so long since I needed to use one of those lol. Back out to the shop I guess, (sigh), I really don't like the location of the cam sync, I wish I had done it before I put the top end back together but most likely would still have to do it again now anyway. I think I got it now though, that is encouraging. I'm done complaining now, thanks for the advice 👍😁
overloaded
I just had to do this - don't use TDC as the reference when you drop it back in. I tried doing it using TDC as the mark and got engine codes and/or mediocre performance and hesitations.
This procedure is for a 3.0L built for the '04 model year.
You want to:
1. Remove spark plugs 2-6, and LOOSEN spark plug 1 a bit
2. Remove the crank position sensor - you'll see a boss with a line on it once it's removed which you will use to judge position off of. You may need to spray a little brake cleaner if it's gunked up.
3. Put it to TDC on the compression cycle(you'll hear a slight hiss and feel the pressure building up when you're hitting compression cycle), then slooowly move it 1 tooth further (each tooth is 10 degrees) to prep for reinsertion. The gap in the teeth will NOT line up with the crank position sensor at TDC, you will see the 5th tooth pointing straight at the line when at TDC. The gap is there for visual lineup with something else.
4. I used a Cardone set that I borrowed from Autozone, if you use that one use the BLUE positioning tool. A correct tool(regardless of color) will hold the flag about 15-20 degrees off-center of the gap, do NOT use the tool that holds the flag on-center. That's for different, but related, engines. OTC Tools' number for the positioner is 6473, you can look at what its angle is on Amazon.
5. Take the sensor cap off the CMP and set aside.
6. Affix the positioning tool to the CMP, point the arrow leftwards about 60-75 degrees, and start inserting. You'll probably have to wiggle a little bit to get it in, don't be surprised if you wind up a little left or a little right of the engine's centerline in the end. If you insert with the tool arrow pointed at the centerline, it'll end up way to the right.
7. Make sure the positioning tool doesn't come loose while inserting all the way, although the assembly will have a small bit of wiggle to it.
8. Tighten down the hold-down bolt to secure
9. Remove the alignment tool, and reinstall the sensor cap.
It helps greatly to remove the serpentine belt off of its top idler when you're attempting this, and to have a good bright light source as well.
