stimmie78
- Jun 25, 2010
- Reaction score
- 1
- Location
- Uinta Basin, UT
- Make / Model
- Ford
- Manual
So I'm working on changing the clutch on my 89 BII. The tranny is COVERED in black dirt/oil crap. Is it all from bad valve covers? Or would it be from a bad slave? The clutch is dry. The flywheel is dirty where the clutch doesn't contact. The goop is inside the bell housing just as bad as it is outside.
Also, shouldn't clutch fluid come out of the hose when it's disconnected from the slave? The pedal was stuck after I got the trans out. After it broke loose some fluid came out but not much.
Here are some pictures of the goop on the transmission if you care to see.
Thanks.
Thanks.
