clutch electrical
mikie
clayton, idaho
88 ranger 2.9. does the clutch need to be depressed for ignition spark on starting?. I am using a remote button on the solenoid to test a new engine installation and get no spark. do I need someone in the cab holding the pedal down? Starter cranks ok and I cant find anything relevant in the schematics. Key is on.
Rick W
4,013
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
I don’t know the real answer, but it should be relatively easy to find the clutch switch and either jump it temporarily or tie it down if it’s some kind of lever thing. If your truck starts, that answers your question. If not, you have to find somebody smarter than me…
Hope it helps.
mikie
clayton, idaho
All suggestions are welcome, thank you.
Rick W
4,013
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Afterthought, you probably know this, but make sure it’s in neutral and make sure the parking brake is set, and it’s probably advisable to actually chock the wheels in both directions, so it doesn’t start in gear by accident.
mikie
clayton, idaho
Gotcha, I always need safety reminders too.
8,372
Yes, the ignition switch in START position sends 12v to starter relay AND coil, in RUN just the coil gets the 12v
If using a remote starter button just put a jumper wire from battery positive to Coil + terminal, it will back feed to TFI module
It was a hold over from the Ballast Resistor days, when there was a resistor on coil positive to reduce the 13.5volts from alternator so coil didn't over heat with engine running, it reduced it down to 8 or 9volts
But if you tried to start the engine thru the resistor it would be only 4 or 5volts to coil
So a separate wire was used that only had 12v in START for the coil, so it had a hotter spark for cold start
Ballast resistor was gone by mid-1980's but ignition switch wiring was still there until 1990's I believe
Rick W
4,013
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
I told you there was someone smarter than me!
mikie
clayton, idaho
Thanks, I'll get after it when the sun shines in the shop door tomorrow!
8,372
Wait a minute..................
If your key is ON(run) then coil/TFI should have 12volts
So clutch pedal would not need to be down, shouldn't matter for spark using remote start/key on
Its another issue if you don't have spark when cranking with key ON
MikeG
752
central Texas
B4000
2"
235/75r15
If you want to know whether the truck will start without the clutch pedal down, why don't you just try it????? Would take about 10 seconds to answer the question with certainty.......
:confused:
