Chrwilkins30's build
det107
23
Vails Gate, NY
It is looking Pretty Solid !!! Keep up the Good Work-
86MUDRCJ
8
Sheridan, CA
I like it man I think I might pick me up a set of those flares
chrwilkins30
6
Mishawaka, Indiana
Pricey but I think they are worth it. It took almost a month to get but that's the only downside.
86MUDRCJ
8
Sheridan, CA
How much did they run ya?
chrwilkins30
6
Mishawaka, Indiana
a little over 400. but its a very clean way to cut the fenders. Ordered from summitracing.
86MUDRCJ
8
Sheridan, CA
That's what I was figuring up.since you have a set you think I could fit 35's on a 4" with those or should I go bigger lift first?
chrwilkins30
6
Mishawaka, Indiana
ive seen it. My plan is to add a 4in SJ class II and 35's. I have seen is with just 4in and 35's. So i would say yes
86MUDRCJ
8
Sheridan, CA
Sweet! Looks like I'm gonna oder a set. Should be here by the time I get enough saved up for my kevlars.
chrwilkins30
6
Mishawaka, Indiana
Finally replaced my brake parts. Heres what I paid for all of it.
Advance auto parts
Rotors- $42.00 (2)
Hose clips- $5.99 (1)
Duplicolor caliper paint- $7.29 (1)
I paid $53.00 for it all with coupon code:icon_thumby:
Later-Brake hoses- $18.00 (2)
Autozone
Reman calipers- $16.99 (2)
2 6ft brake lines- $6.99 (2)
Fittings- $2.99 (1)
Brake fluids- $6.99 (1)
Brake Cleaner- $3.99 (1)
I paid $37.00 with reward points
Rock auto
Timken Wheel bearings- $8.78 (4)
Timken wheel seal- $4.90 (2)
Paid close to $50.00
Just realize I paid almost $200 for all of it. Dang!
Just a few pics I took.
chrwilkins30
6
Mishawaka, Indiana
Just ordered my switches from summit which include 4 daystar switches (blue,green,red,orange) and a rugged ridge switch housing. Switches ship out today and the housings coming from manufacturer so Don't know when ill get that.
Found Out: 2 switches switches come in Monday, other 2 Tuesday and housing on Tuesday as well.
chrwilkins30
6
Mishawaka, Indiana
Got everything monday when I was at work,Installed today.
assembled:
Needed a little clearance. nothing a hacksaw blade could'nt fix.
finished install:
Going to hook up the relays and rook lights on thursday and prob continue on to friday since I have those days off.
chrwilkins30
6
Mishawaka, Indiana
After stumbling Thursday to figure out my first relay hook up I got nothing accomplished. But searching i figured it out fairly easy today.
Day Shots:
Night Shots:
Switch illumination:
chrwilkins30
6
Mishawaka, Indiana
Replaced the sway bar link bushings
Seize bolt
After wire wheel
Primer
Paint and assemby
chrwilkins30
6
Mishawaka, Indiana
First real Snow
Around 9in and got through everything in 2wd no problem.
