Chevy TRE's
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
I've seen 3/4 used, and they hold up fine. I'm using the stock pitman arm on my truck and I just had it reamed out to the proper taper. I'd assume the knuckles would be fine as well, as there's plenty of material there.
-andrew
Bent Bolt
4
Edmonton,AB
Solid Axle Swap 4x4
But you had to ream them ?? The chev TRE won't fit the stock pitman arm ??
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
No, they're bigger. Like said, there's plenty of material around everything so you can ream things bigger no problem.
Bent Bolt
4
Edmonton,AB
Solid Axle Swap 4x4
Thanks all. Thats what I was looking for.
brendank
It's only money...
Saskatoon, Saskatchewan
Should work just fine. I actually run the 1-ton TRE on the top of my pitman arm.
I have the XCUT reamer that is the proper taper for that TRE. I don't need it anymore, so make me an offer if you want it.
