Q's & suggestion
I need help looking for a good lift/duration cam for a chevy 350 carburated. I need really low end torque
Is he rebuildin it?
If so, I'd suggest goin to "NorthernAutoParts.com" and orderin their 350 special kit (less than $200 for master kit= pistons, rings, bearings, cam, lifters, oil pump, gaskets) w/flattop pistons.............there is a detail spot where you choose rings, bearings size (std, 010,030 etc.) & you can choose Clevite bearings, FelPro gaskets, & cam of choice for a lil' more $.
He should be able to build that stock 350 ready to drop in for less than $500
, now if he's goin 30 over or must grind his crank, then machine shop cost is a lil' more.
GOOD LUCK & if ya need anymore Chevy contacts, hit me up.............
