eightynine4x4
- Oct 15, 2020
- Reaction score
- 178
- Location
- New York
- Make / Model
- Ford Ranger
- Engine Type
- 2.9 V6
- Automatic
- 2WD / 4WD
- 4WD
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
1989 4x4 Automatic 2.9l short bed
Has Rancho 4” suspension and also a single block lift in bed. Already removed one block in bed (they were stacked) and also already have removed the 3” body lift in bed.
I’ve taken a few ganders and think I have the general sense of how this is going to go.
Not referring to the actual labor of doing the lowering, since I think i have a good game plan. I’m just concerned about accidentally overlooking a cable or connection or something that needs to be disconnected or relocated and shortened or lengthened before returning to OEM.
I’ve only taken a couple quick glances at this but it seems like the previous owner had rerouted some things under the can instead of through the little hole in the firewall on drivers side. I will add pics soon. It’s hard to tell if the lowest edges of cab, when lowered, makes full contact with the frame/hardware below and that any lines/wires/cables down there would be pinched and busted when I lower it. I’m thinking they would and that I need to reroute through firewall.
How about the steering wheel and column? As far as the column, it seems it might be ok since the joints are flexible/pad types (can’t remember what they’re called) so could tilt down a bit and be fine. But obviously my steering wheel might want to jut further into the cab when lowered. Should be disconnecting some mounts in cab for this and then rebooting in a new position? Or disconnecting a joint in column and reconnecting after? Is there a length adjustment in the column itself?
How about the transfer case shifter? Should it just be fine and simply pop up higher into cab? The boot seems like it’s just there on its own, flexibly, and no hard mounting is connected to the shifter so it could just slide right up and be fine.
Lastly, what about the automatic shifter in steering column? Does something need to be adjusted underneath the cab so that the shift positions are at the proper spot after the height change?
