Check Engine Light, 51 Erorr
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Is that the emissions book @AndyB.
AndyB.
142
Cincinnati, OH
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Flash code 1-1?
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Code 11 - System Pass
Means the ECM is operational
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Just my ghost miss that nearly makes the engine stall, what a shame the computer can’t pick up on that….
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Is it a dead miss or random?
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Random generally under light to moderate acceleration. Just pulled original injectors back out cleaned and resealed all of them same thing. As it gets hot, seems to get better. Temp gauge still dead 0 but swapped original temp sensor and switch back in and error 51 code is gone. Still missing.
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Random and not consistent doesn't make things any easier.
Did you use Motorcraft or Autolite plugs? Have taken a look at them since you changed injectors?
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Haven't pulled plugs since bad injector incident fixed.. Motorcraft plugs.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Truck was hot for probably 20 minutes straight ran 90% fine hardly missed. Cooled down an hour runs like a piece of shit.
