Center Hinge Brackets
Kona
06/2014 OTOTM Winner
Canada Military - Veteran
ASE Certified Tech
Kamloops BC
7"
35x12.50x15
About to put in center hinge brackets , Skyjacker class II , I have Skyjacker 136s springs in a Trailmaster 4" lift. So stock radius arms Trailsmaster radius arm brackets and dropped pitman arm Skyjacker 136s springs. 4 or 6 inch hole , and if 6 should I use a 1" spacer under the soft Skyjacker springs?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
4.0L ext cab...with the 6" springs run it in the 4" hole. You will have better/easier alignment, plus is adds a bit of ground clearance.
Kona
ASE Certified Tech
Kamloops BC
7"
35x12.50x15
So wait till I get extended radius arms and longer springs to go to the 6" hole?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
You can get the ext radius arms if you want, but what hole you use for the axle is primarily dictated by how tall your coils sit.
If you didn't specifically get the Skyjacker pt# FA600 drop pitman arm, you will absolutely need that as well if you use the 6" hole.
Kona
ASE Certified Tech
Kamloops BC
7"
35x12.50x15
I have the Trailmaster drop pitman (I think) my steering with 4" hinge & skyjacker 136 springs looks good.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Kona
ASE Certified Tech
Kamloops BC
7"
35x12.50x15
LOL, tried the Skyjacker 136 coils in the 6" hole w/stock radius arms!!!! Gross feeling, uncontrollable above 30 mph! Turned out the drivers hinge bracket was bent in 4 or 5 places/directions.
