cb anntenna help
grant94
Citrus County, FL.
2.3l L4
I picked up a whip antenna for free. i need the wires. where can i find the wires? also i was wondering if i would be able to hook the antenna to my radio.
Thanks,
Ryan
RedComet6342
North Carolina
By wires i think you mean the coax cable which you can easily find at any truck stop or radioshack
now im not to sure about hooking it up to a radio other than a cb radio but i doubt it would work
feellnfroggy
28
Knoxville, TN
It will work, adapters are also sold at truck stops, but personally I wouldnt use it on a radio or anything other than a CB. I would also take your cb to a mom and pops electronics shop and have it tweaked. Get a good powermike and go to flea markets and swap meets where you can find cb amplifiers for rediculous cheap. I found two setups in florida for 20 bux each. Or join a hunt lcub, they can help you find all the good stuff too.
grant94
Citrus County, FL.
2.3l L4
thank you. if anyone else has any input please feel free to post.
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
I picked up a whip antenna for free. i need the wires. where can i find the wires? also i was wondering if i would be able to hook the antenna to my radio.Thanks,Ryan
As stated COAX is needed, maybe an Antenna Mount.
CBs are quick and easy but there are a few things that need to be done.
First off, the antenna is the most important part of a CB system, it can make or break it, hopefully the one you have is good.
Next is good quality coax, buy only Belden coax, should be available at most Truck Stops; RG-58U is good, RG-8X is better.
(DO NOT BUY COAX AT RAT SHAQ)
Now what type of mount will you be using, do you need a Stud Mount ?
After that just hook up the red and blk wires directly to the battery, putting a fuse close to the battery end, mount the antenna, run the coax and make sure to get the antenna tuned for low SWR (standing wave ratio), a must do.
Good Luck,
kris97ranger
36
lisle ontario
4 litre and 7.3 litre
i have dual antennas one on my cb and one on my radio and they both work fine.
________
Faster_CumSquirt4u
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
grant94,,
where you going with this ?
