Carburetor cold starting problem
Barbara
6
Michigan
Ford ranger
The choke isn't working and it's leaking gas. Instead of rebuilding the carb can I swap it out with a 2100 is it compatible.
17,910
SW Iowa
What engine?
rusty ol ranger
2.9 Mafia-Don
7,585
Michigan
177 CID
85 2.8 correct?
We answed this already for you once i believe lol.
But anyways, IIRC you were already durasparked...if so...then yes a 2100 will work but the 2100 is actually a step down from the 2150 in terms of cold driveabilty and a few other things.
It will not gain you anything,.
Barbara
6
Michigan
Ford ranger
85 2.8 correct?
Thank you, I think it's better if I get the new carb instead of rebuilding this one. It leaks gas n the choke doesn't work even after a changed the electric choke n that other thing that works the choke can't think of what it's called lol
rusty ol ranger
2.9 Mafia-Don
7,585
Michigan
177 CID
Just buy another 2150. Youll thank me later.
Barbara
6
Michigan
Ford ranger
I bought the 2100 started right up now I'm trying to adjust the idle n mixture
rusty ol ranger
2.9 Mafia-Don
7,585
Michigan
177 CID
Turn the mix screws all the way in till lightly seated...then back out 1.5 turns. That is factory baseline. Adjust from there (on a warm engine of course). Theres a certain "feel" to it that if your not experenced with carbs you should pry utilize a vacuum gauge.
Idle speed is also a feels thing. You kinda just know. You dont want it racing...but you dont want it on the verge of stalling either.
Ill usually back it off till the idle is obviously low...then go 1/2-1 turn back the other way.
