Can it be done?
dasroach
Alright i got some questions. First of all, has anyone out there been able to mod their ranger to run a solid axle from an 80's 1/2 ton gm product? Im debating pullin the drivetrain an goin bowtie simply b/c i have a set of gm axles, a fresh 383 and a four speed saginaw with a np205 transfer case...Would it be worth it?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
assuming you have a stock powertrain it could involve exaust reroute and custom t case adapter.
what powertrain do you have? if your running the 383 then just install it all and get it awwn
86ford
rocky river ohio
FORD
4.0, abused and misunderstood
That is a BIG project. you would be changing to a passenger side drop ( I think) not to mention tackling some SERIOUS clearance issues with the motor and trans.
"would it be worth it"
for me, NO WAY. If you want to be different, go for it. but that is MAJOR work.
86
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
86
:icon_confused:
if he ues the gm shit its easy...adapting the ford v6 stuff will take some doing
dasroach
Actually i plan to make the drivetrain all gm... still debating on whether to use the four speed or go with a th400.... yeah i know it would put the transfer case out on the other side but hell its not like ill be sellin the truck or anything. as for clearance i have a plasma cutter and a sledge its possible
dasroach
BTW i have a 98 1/2 ton 6.5 powered chevy silverado as my daily driver
Tony Raine
17
Jonesboro, AR
302
it may be easier to bolt all your gm stuff to a gm frame, then bolt your cab/bed on top, rather than adapt all the gm stuff to the ranger frame.
either way, i say go for it :headbang:
Wicked_Sludge
43
Westport, WA
3-point-GO
anything can be done with enough time, money, and oxy-acetylene :icon_thumby:
