- Sep 7, 2021
- 56
- Boise ID/Camarillo CA
- Ford Ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 3"
- Tire Size
- 31x10.50R15
Son and I are doing a clutch job and have come up across a few hickups.
1) Looks like this is the "Neutral sensing switch". Right? How do I get the electrical connector off? I tried unscrewing it, I tried prying on it, and I cannot get it to budge. I ended up cutting the wires to get the trans out. The wires are super old and brittle so I will probably replace them anyway but it sure would be a lot easier if I could get the connector off. I know I can unscrew the whole thing but I would think the wires can come off on their own, right?
2) I feel like there should be a boot or seal up here around the shifter. We have the floor boot but under the floor boot is this (see pics). I see gobs of oiley dirt all over my trans and it looks to be from a leak around the shifter. I don't even see how to take this apart. Is there something missing here? Can I fix this?
3) It took us 6 hours to get this out. (annoyed) Hardest part was getting the bell housing to clear the cross member/sway bar mount AND the floor board. We also broke one of the bolts that hold the Y-Pipe to the passenger side exhaust manifold so now we have to pull the exhaust manifold out and drill/tap it. What a pain ITA. Any advice to make installing this trans/case easier?
Tomorrow we will install the new clutch, pressure wash the crap out of this biatch and start putting it back together.
