cab swap
sparkey
nc
88 bronco II to ranger cab both are 88 both are 2.9 both ran when I started the swap. Every things ready to go but when hook up batt turn on the key I have a relay start chatering I have spark at the coil unplug the relay and the spark goes away when it is unpluged it sounds like the pump on the fram rail is making some kind of a sound plug it up and I think it quits. The inertia switch when I push it in should it stay in or pop out a little thanks for any input on this
sparkey
nc
The relay thats making the noise is brown I have tryed swaping it out for another relay but no change. If I unhook the fuel pump it quits making the noise I tried another pump hooked it up with out hooking the lines up no noise hooked fuel lines up noise came back kind of like a growl I some one has something to say
