C clip removal
Blackdog
Zillah Wa.
I need to remove my axles. My diff has the factory LS. How can I remove the C clips? Does the S spring have to come out first?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
No, pull the bolt holding the crosspin, slid the crosspin out, push the axle in, remove c-clip, remove axle.
Blackdog
Zillah Wa.
OK, tried again and got one axle out. The other clip is a real tight fit, I'll try it again in the morning. Noticed a loose "O" ring under the C clip, what's the deal with that? Thanks
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
O-ring, I really have no idea :icon_confused:
metalmacguyver
Yeah, I built that.
11
Plymouth MA home, Buzzards Bay MA
4.0, 7.3
that o ring is there to hold the C-clip during assembly at the factory.
ehayes928
Michigan!
2.3
is it mandatory that you have the o-rings when you put it back together? I pulled one shaft and no o-ring on the c-clip end...
86 slo-vo
02/2011 OTOTM Winner
36
owensboro, KY
no you dont need the o-rings
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
The O-ring just holds the C-clip in place until you give the axle shaft a good yank outwards.
It's an "assembly aid"
a Damned convenient one...
AD
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
Thats good to know about the o-ring. When my rear end needed new seals put in it, we ripped it out on accident and never put a new one in but all has worked well for the last 3 years.
woofer2609
Vancouver BC
Mazda
DOHC 2.3
O-ring fits towards the wheel side of slot, with c-clip inboard of o-ring
