BroncoII w/ body lift Question....what rad hose??
ragajungle
Burlington, WI
2.9L V6
I have a 3in body lift and am trying to replace my upper rad hose. I bought an OEM one and it doesn't fit at all... Tried a different parts house same thing -- no dice. What year/model hose will fit with my truck.
Thanks,
Mike
Early Explorer maybe?
ragajungle
Burlington, WI
2.9L V6
Adms08 thanks, I have a 94 EX and it looks like it might fit but when I put it on mine it binds on one of the bends and I am afraid it will rub on my CAI...
Bump any one have any more ideas?
whocares
In some of the different swaps I have done over the years I have bent a coathanger in the rough shape of the hose I needed. Take that to the parts store and browse through their hose selection. You will be able to find what you need that way.
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
Junk Collector
Truck of Month
4,832
Rapid City SD
I would also suggest a universal flex hose. Or the coat hanger trick. I had to use a flex hose for the lower on my 302 swap.
xkotyx
20
Waynesboro, VA
do the flex hose's work pretty good? seem durable?
Junk Collector
Truck of Month
4,832
Rapid City SD
Yeah they work great. Probably way more durable than your standard hose. The name is misleading though, they look like you could tie them in knots but they're actually pretty stiff.
85_Ranger4x4
17,909
SW Iowa
But they don't pinch off when you flex them like a normal hose.
ragajungle
Burlington, WI
2.9L V6
I guess I will have to try the flex hose then.. I was/am skeptical b/c it looks too rigid - like it would put pressure on the upper rad inlet.
