Bronco II sputtering and no power
ScarletStang
North Carolina
Ford Bronco II
The MAP sensor is near the firewall to the right of the upper intake manifold, at the rear hood line.
Okay, cool. I found it. I might try replacing that if the new fuel pump doesn't fix it. Still waiting for it to come in the mail.
As I was looking at this thread again a thought came to mind.
Make sure you have the firing order correct. A couple of crossed up plug wires could cause your sputtering and backfiring.
I'm sure it's correct. I even double checked when I did the wires. I didn't even open the hood between the time it was running perfect to when it started running bad.
ScarletStang
North Carolina
Ford Bronco II
Shoutout to FedEx for deciding to not deliver my fuel pump and sending it all over the place. Now it's being sent back and forth between the same two FedEx facilities in Florida. Been back and forth five times now smh. Why is nothing ever simple?
ScarletStang
North Carolina
Ford Bronco II
It sounds like your fuel pump in need of attention
DirtBronco, you hit the nail on the head. New fuel pump in and it's running like a champion! That is after I stayed on the phone two hours with FedEx trying to locate my fuel pump, I finally got it 16 days after ordering it.
Thank you to everyone who posted trying to help!
OGdr
9
Oak Ridge
Fyi, harbor freight sells a fuel pressure test kit. It’s cheap and the one I bought leaks a little, but it’s only $20 and invaluable when diagnosing these sort of problems
JerryC
56
Tennessee
I have that same one :). I had to teflon tape the threads to stop the leaks.
SenorNoob
624
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
