Bronco II GVWR
Bronco_Chuck
Los Lunas, NM
84, 86 & 89
2.8 & 2.9
I just wanted to know if any body knew the Gross vehicle weight rating for a 84 bronco 2?
thanks.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you can't go through it or around it, then go over it.
um something like 10 pounds. don't try to tow a whole lot with it until you go through the transmission.
Bronco_Chuck
Los Lunas, NM
84, 86 & 89
2.8 & 2.9
im sorry i ment the weight of the vehicle. not how much it can pull.
Jorley
Crawfordville,Fla.
2.8 duraspark
Mine tipped the scales at around 3300 lbs.
Wicked_Sludge
43
Westport, WA
3-point-GO
gross vehicle weight is the weight the truck will weigh when fully loaded with the maximum legal load.
what your looking for is called curb weight.
Jorley
Crawfordville,Fla.
2.8 duraspark
Yeah, I should have mentioned that in my other post. That weight(3300 lbs) is totally empty and about 1/4 tank of gas.
sweetwaterbroncoII
Sweetwater, TN
2.9L
You can find that information by decoding your VIN......if the 4th letter is A it is up to 3000 lbs, if its B 3001-4000 lbs, or if its C 4001 lbs and up....
tucking30s
If the curb weight is 3000-3400 lbs, what is the weight of the front vs. rear of the vehicle?
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The GVWR rating on my '90 is 4360lbs.
Weight distribution (unladen) is very close to 50-50% on a BII.
dirtsquirt
Edmonton Alberta Canada
1987 and 2005
ford And jeep
2.9 And 4.0
Look around for a truck stop or commercial truck scale along a hi-way, most truck stops have a scale u can get your front axel, rear axel and truck weight to your set up.
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
thanks.
It's printed right on the safety and compliance label on the
end of your driver door.
AD
B2 Addict
9
Lavergne, TN
Solid Axle Swap 4x4
37x12.50-17
My 84 says GVWR 4160 pnds on the door sticker.
GAWR for front is 2120.
GAWR for rear is 2390.
Guessing GAWR is gross axle weight rating.
No members online now.
