bronco 2 2wd questions
dgarner08
hey guys i was wondering if there were any differences between a two wheel drive b2 frame and a four wheel drive b2 frame. also would a d35 bolt into a two wheel drive b2 frame without modification?
thanks
dusto2
scv ca
frames are the same, brackets are different but they are interchangeable, there is a tech write up on this one, its actually not that bad you have to swap 1 bracket unless you want to lift it then you use the 4x4 brackets, and for the tcase since yours has the dummy tcase it just a swap out and cutting a hole
engdept
5
Charlestown, IN
ONLY the passenger side axle beam bracket is different between the 2wd and 4wd Bronco II's. The driver side beam drop bracket is identical between the 2wd and 4wd Bronco II's.
The passenger side beam bracket is a simple swap to a 4wd beam bracket. I have one if you want it $20 + shipping.
Other than that 1 beam bracket, it is a total bolt in installation.
