Broken wire
Jim Wright
17
McCleary Wa
I have a 1989 Ford Ranger with a 2.9 l four-wheel drive. When removing the motor to rebuild I pulled this wire loose. It is located between the battery box and the air cleaner box beneath the starter solenoid. It is a black wire with a green stripe going into what looks like a fuse. Coming out of the fuse it is solid black. Any help directing me to where this wire goes would be greatly appreciated. Thanks Jim. PS pics attached.
broncc
566
MA, USA
Ford Bronco II
5"
Giving my truck more money than it deserves.
I believe that is a ground. That is a one pin connector, not a fuse.
Jim Wright
17
McCleary Wa
Makes sense,. I thought I had All the wires disconnected but it would have been easy to miss a ground. Thanks for replying. Jim
Paulos
210
North Carolina
1987 STX
The wiring diagram shows one end of the wire going to the frame where the ground from the battery bolts to before continuing to the engine block. The other end going into the wire loom supplies a ground for the O2 sensor, ECC relay, and the ECM.
Jim Wright
17
McCleary Wa
Thanks for the reply so it's definitely a ground that's good to know, I'm going to go hook it up to a good ground. appreciate it. Thanks Jim
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
That’s going to be important.
dirtymike
112
knoxville TN
Ranger lwb
1 inch spacers
P23575R15
Do unto others then Split-probasti me et chognuisti me
Sure is a purdy red
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Paulos
210
North Carolina
1987 STX
Fire? I've never actually seen the fire through all the smoke.
