Breaks soft go all the way to the floor
1987ranger12394
115
Hickory NC
I rebuilt the rear drums and replaced the disc calipers on the front. when I bleed the break lines I get most of my break pressure back for a short period but then it's gone again. I'm not loosing any fluids also. Power stop calipers
Uncle Gump
Token Old Guy
13,471
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Rear brake adjustment plays a huge role in pedal height... ensure rear brakes are properly adjusted
I would also ensure you don't have a rubber line ballooning up under pressure.
You sure there is no air left in the system? No Leaks?
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
You still have air in the system that is either trapped or you didn't bleed it all out the first time.
Start at the right rear then to the left rear onto the front right and lastly the front left.
You can make a catch can using a soda bottle and a vacuum hose. poor some fluid in to the bottle insert the hose so the end stays under the top of the fluid, crack open the bleeder valve and press the peddle. lift up slowly and repeat to bleed but be sure to keep the master cylinder reservoir at least half full because if it goes dry you can suck air in the system and need to start again.
1987ranger12394
115
Hickory NC
No leaks. And theres no air in the lines when I get done bleeding them but I get air back in after it sits for a while. As if i never blead them. None of my metal lines are leaking and i dont see any leaks from the rubber lines. Could the rubber lines pull air in if they went bad?
1987ranger12394
115
Hickory NC
Me and my wife blead them till I was filling half a water bottle each. I went through 3 qts of break fluid. I'm on my fourth qt
1987ranger12394
115
Hickory NC
There is no air after I bleed them. But the next day I'll have no breaks again and have to bleed them
You said you bled the lines. Are you cracking the banjo bolts, or opening the bleeders?
Also, have you replaced the crush washers, or were they reused?
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
IN your pic it looks as you have 2 banjo bolt gaskets at the bolt head are there 2 or is this just an optical illusion?
EDIT: one washer (crush seal) per side at the caliper if you have both on one side will will let air in and most likely is letting some fluid out also.
1987ranger12394
115
Hickory NC
I use the bleeder and a hose on the nipple with the end in a bottle. I have my break pusher start to press the brake while I crack bleeder than hold till bubbles stop tightening up than letting go of break rinse repeat. Yes new crush washers that came with calipers.3
1987ranger12394
115
Hickory NC
It came with three in the pack and for whatever reason. I just copied what was on there previously two on top and one on the bottom
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
Double gasketing will usually leads to leaks. Maybe @adsm08 can shed some light on this one?
1987ranger12394
115
Hickory NC
Good to know I'll fix that. the one I pulled off had three on it and my new pack came with three must just be an extra in the pack in case you lose one.
1987ranger12394
115
Hickory NC
Explains why the brakes didnt work before I started all this. Dam do I feel stupid
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
I would just check both sides to make sure it isn't the same way on the drivers side also.
sheep herder
1,024
sheep pen
If it ain't broke, break it.
Breaks are broken. Brakes slow you down.
