Brake Issue.
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
The brakes on my ‘06 (2wd) are acting up. I did rotors, pads, drums, wheel cylinders & hardware. Normal driving is fine but if you try to stop quick, the pedal drops to the floor. You feel and hear the slight sound of the ABS noise and pedal vibration for a sec. No brake light, no leaks, no loss of fluid in the master. I’m guessing the master is bad but I’m afraid it’s the booster.
I only drive this truck 4 or 5 times a month and the problem wasn’t constant. But driving it home a week ago it kept happening. All I thought was.. “Time to trade it”. I had a week to calm down. Lol
Bronco ii Man
43
Southport NC
Ford Bronco ii
2.8 V6
2.8 v6
31x10.50-15
Kinda sounds like a master cylinder problem. No leaks external that you can see but leaking inside itself. Had it happen on my Bii.
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'm pretty sure it's your ABS going off... and I've have some issue with the front wheel speed sensors.
Tell me... does it tend to wanna pull the truck left or right when it happens?
These wheel speed sensors tend to fall off when at slow speeds... but the others say it's still moving so ABS tends to unapply whatever speed sensor falls off.
Bronco ii Man
43
Southport NC
Ford Bronco ii
2.8 V6
2.8 v6
31x10.50-15
Press the brake a few times to get a full pedal and then press hard on it! If it holds a few seconds and slowly goes to the floor your master cylinder is bad! Booster will 90% of the time cause a vacuum leak! Thus causing a high idle situation! I’m sure you got all the air out when you bleed the system? Could be the culprit? Couple of things to look for.
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
Yea. I’m just a crabby old man now .. lol. I’ve been wrenching for over 35yrs and after a 50hr week of fixing people cars, the last thing I want to do is work on my own junk anymore.
I’ll have to pick up a new master. 👍🏼
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
Yea but I’m not getting an ABS light. This is my issue with an “older” truck. I’m tired of chasing issues.
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
It stays hard. It only drops out when driving and a slightly aggressive braking.
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You won't get a light... it's working as it should.
Does it pull one way or the other?
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
Uncle Gump
Token Old Guy
13,462
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Then it could be the rear sensor. If it pulled... it would be easy to tell what sensor went bad.
I would look at wheel speed data... or have someone with a tool look.
I guess I should have asked the obvious.... you don't have a wheel locking up... do you?
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
No lock up. I have a Snap-on Apollo at the shop. I’ll have to take it for a quick ride.
Bronco ii Man
43
Southport NC
Ford Bronco ii
2.8 V6
2.8 v6
31x10.50-15
Weird no lights, no pulling, and only goes to the floor on hard braking! Got a gremlin somewhere lol!
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
Yep… I hate chasing gremlins now.
I need to get off my ass and finish the project.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Same truck???
