- Jan 16, 2020
- 50
- Ohio
- BII, Rangers
- 2WD / 4WD
- 4WD
1986 Bronco II. I've installed a 3" stage II lift from James Duff and I am having an issue when I turn full lock to the left. When I do that the brake caliper (actually the brake line/bolt) touches the shock to the point where it depresses the piston and makes it so I have to pump the pedal several times to get brakes back. Has anyone else run into this? The brakes are stock and I know they switched late in '86 to a different style caliper. Can anyone verify if switching to the newer style caliper will fix this? It's really a bad feeling when I turn too far and there is no brake pedal. I won't let anyone else drive it because of this either. I've sent a message to Duff but I haven't heard back yet.
Also of note this is D35 swapped and this condition was still present on the D28.
Thanks.
Since everyone likes pics and I like showing this thing off...
Thanks.
