Brake Booster Question
ford4wd08
510
Alcoa, TN
2.8 V6
Should a brake booster hiss at any point during applying the brakes? (Loosing vacuum I assume?)
I've never experienced it before this during using the brakes.
Could my booster have a leak?
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Is it a steady hiss? Or a whoosh only til the pedal gets firm?
If it's steady... most likely a booster.
A whoosh.... just displacing air from the bellows.
ford4wd08
510
Alcoa, TN
2.8 V6
Let me check and I'll let you know.
I think it's only when I apply the brakes...
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Lets make sure we understand each other...
during the act of pushing the pedal down... a little whoosh sound is probably ok. But when then pedal stops and brakes are applied... it should be silent... no hiss.
ford4wd08
510
Alcoa, TN
2.8 V6
Understood. I'll confirm when I drive it tomorrow.
ford4wd08
510
Alcoa, TN
2.8 V6
I believe it is a woosh, I had just never heard it before.
Thanks for the feedback!
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Welcome...
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
If a vehicle makes a new noise it's usually a sign of something going wrong.
ford4wd08
510
Alcoa, TN
2.8 V6
I agree with that.
Guess my comment is from driving my 2016 f150 daily to the 85 bronco 2. The f150 doesn't whoosh. Lol
Uncle Gump
Token Old Guy
13,460
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Next time you park the F150... after you shut it off... push the brake pedal. You will hear it whoosh
ford4wd08
510
Alcoa, TN
2.8 V6
@Uncle Gump @19Walt93
I drove it again. It does hiss when I press the brakes and hold the brake pedal mid stroke.
If I hold it to the floor it stops.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
Time for a new booster.
