bought a used suspension lift
Jsommers
michigan
so looking around on craigslist i found a 4 inch lift off a 1990 bronco 2 and decided to buy it.
it came with blocks for the rear, coils, ra drop brackets, and beam drop brackets for $150
i dont think i came out too bad.
so now i need to find a pitman arm and some shocks on the cheap too.
ive seen shocks for around $130 online and a drop pitman arm for about $80.
deffinately dont have $210 more to throw around.
so any ideas? :icon_confused:
or is my lift going to have to wait for more finacial motovation? :dunno:
99RangerKrazy
Kennewick, WA
For shocks, check out some on eBay called Skyjacker Scratch and Dent. They're in perfect working order; however they just have some sort of cosmetic blemish. But I think they're only like $25 a piece or something like that. That'll save a few bucks.
For the pitman arm, check out the TRS classified sections or put a post in the Wanted section, maybe someone has one on here that they'll sell for cheap.
Jsommers
michigan
ok thanks for the help maybe some others will chime in with a solution
but i guess ill keep looking around.
not like i can do much since its below freezing and theres 6 inches of snow every where
Lrpalo
If you are gonna be doing any wheeling with it you are gonna want some extended brake lines which can run $100+. But you can get the lines off 91 f350 and have to bend the metal tubes at the bottom but work fine.
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
woke up to -19 this morning and still have a foot of snow on the ground. :annoyed: i hear ya on waiting. think i'll be waiting till spring (April up here) before i start my projects! good luck with this.
Jsommers
michigan
yea I was planing on doing the lines that are in the tech library when I actually Start to wheel it. But just want it up a little higher for now.
