Bolt in swap
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
What I meant is usually you mark the drive shaft but I'm replacing rear end. How do I re install driveshaft so there are no issues ?
Don’t worry about it.
SGeyer
Maine
Ford Ranger XLT
I apologize. Mind is everywhere today. Thank you.
scotts90ranger
4,375
Dayton Oregon
2.3 Turbo
Yes, it will only bolt on in two orientations, doesn't matter which one you use.
JMF661
120
Montana
Ford Ranger XLT
Stock
31” x 10.5”
When I replaced my entire rear end and swapped to a one piece driveline, I simply cleaned up the mating surfaces with a brush and timed the slip yoke to the shaft after disassembly and a greasing. Have not had any vibration issues.
Common practice is to mark the shaft and mount surfaces to help prevent new vibrations from cropping up. It’s a precautionary deal, in your situation it won’t help you much as you are completely replacing the rear end.
SGeyer
Maine
Ford Ranger XLT
