Body mount hardware?
97ranger_crc
O'Fallon Missouri
ranger xlt
Im getting ready to put polyurethane body mount bushings on my 97 2wd ext cab and I need new hardware, the hardware I have is rusted down to nothing. And 3 of the mounts literally fell out therefor leaving me no choice to get new ones. Does anyone know exactly what I need ? Length of new bolts/ size and what washers should I get when I go to the hardware store tomorrow
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Seems to me someone on here just bought new body mount hardware... maybe @pjtoledo ?
Bgunner
1,105
Western Mass.
Ford/Ranger XLT
225/70/R15
LMC truck will get you the hardware that you need. I have the bushings and will be ordering my hardware through them as needed since I have very little rust on my 94. The body bolts are a very fine thread so most hardware stores will not carry what is needed.
97ranger_crc
O'Fallon Missouri
ranger xlt
Im trying to do this on somewhat of a budget I cant make something else work?
Roert42
5,065
Kintersville, PA
Ranger XLT
4.0 SOHC
Not sure what your body mount hardware threads into, but you could just buy some grade 8 hardware and thru bolt it with some nuts.
Bgunner
1,105
Western Mass.
Ford/Ranger XLT
225/70/R15
they need to be case hardened, grade 8's will do, and as fine a thread as possible. A course thread does not have the strength as a the fine threads so this is an important point to pay attention to.
why not just purchase the kit with them all in one, bushings and hardware?
97ranger_crc
O'Fallon Missouri
ranger xlt
I will make that work and yes I know exactly what you mean about fine threads. I wanted to do it this way because next spring im taking the body off anyway. I just need it to get me by until March or so when I do a more in depth resto and undercoat the frame and do body work and repaint etc.
85_Ranger4x4
17,999
SW Iowa
I kinda copied the construction method used for some of the aftermarket options for two of mine (I only needed two and didn't want to buy a whole set) Two big washers (from John Deere dealer. You can check around, duff used to make a kit for older trucks.
97ranger_crc
O'Fallon Missouri
ranger xlt
Do u have a list of what you got by chance
85_Ranger4x4
17,999
SW Iowa
Those two washers, i measured my old mount for the tube length.
97ranger_crc
O'Fallon Missouri
ranger xlt
The tube your talking about it the metal pipe like spacer that goes in between the polyurethane mount itself right
Junk Collector
Truck of Month
4,870
Rapid City SD
Bolts and big, thick washers from the hardware store. There's no reason to get crazy, grade 8 is fine, course thread is fine, I'd be comfortable with grade 5 even. The factory style fasteners kind of lock the bushings to the body mounts which is nice but not necessary for our purposes.
97ranger_crc
O'Fallon Missouri
ranger xlt
Okay perfect. Thank you so much!
