Bleeding Bake problem
Cricket
Brake pedal goes to the floor/ fluid okay. Installed new breaks all around plus, one rear rear break cylinder on right side passenger side,
No fluid coming out of right rear passenger side.
Have tried to start engine. no fluid & Then I blew out the lines with air. Still no change.
PLEASEHELP AS I NEED VECHILE.
THANKS DEAR FRIENDS FOR YOUR HELP; THANK YOU SO MUCH, <3
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Bleeding brakes is fairly easy...but I suggest using the one-man bleeder kit if you are having problems.
What are you using to bleed them with and are you getting any fluid out of the rear passenger brake cylinder?
If not...remove the bleeder screw and have someone pump the pedal GENTLY...be prepared to catch or mop up brake fluid if it starts to flow and protect your eyes...nasty stuff...
tomw
46
toenails of foothills NW of Atlanta
lima bean
vertical and above ground
In addition to the advice of Mark_88, if you replaced the master cylinder, it most likely needs to be 'bled' before trying to bleed the rest of the system. There should have been a 'dual tube' bleeding kit in the box with the replacement master, along with instructions on how to bleed it. The master cannot bleed the calipers & wheel cylinders unless it has been bled. It will just pump air...
If you have ABS, the procedure is more complicated. I don't, and thus cannot elaborate.
tom
Cricket
TomW/Blled Brake Problem
Thanks for the info. I came to the conclusion of the master cylinder and I will
be replacing that this week.
Thanks for the info on this matter. I have tried everything the other people have suggested and it all worked except for the right rear passenger wheel.
I aappreciate your help Tom and I will let you know how I make out :)
