- Feb 9, 2010
- 19
- Age
- 35
- Menomonie, WI
- Ford
- Engine Type
- 4.0 V6
- 2WD / 4WD
- Solid Axle Swap 4x4
- Total Lift
- 3"
- Tire Size
- 37x12.50 Pitbull Rocker MTs
- My credo
- Custom everything! Purists look out!
Most Recent Truck Picture:
Modifications from front to back:
Stinger/clean tube bumper
8500 Lb Superwinch
Chopped Grill
Hood Pins
Re-centered Stock Front Fenders
Warn Premium Hubs
4" Front Stretch
1979, F150 Dana 44 Solid Axle (Narrowed to 60") Spool and geared to 4.88
Solid Diff Cover
F250 Shocks and Towers in the Front
XJ 6.5" (180ppi) Coils
1 Ton Tie Rod Ends
1.5x.25 Drag Link and Tie Rod.
Early Bronco ChroMoly Shafts with CTMs!
37.x12.50X15s Pitbull Rocker MTs on Trail Ready Aluminum Beadlocks
Quick Release Door Pins
Painted Dash
CD/IPOD Deck
Aftermarket Seats
5 Point Harness (now just a 3 point)
True Flat Belly Skid
Manual 1350- Manual 1354 Doubler (Homemade sector shaft and plate)
15.5 Gallon Beer Keg (Half Barrel) Gas Tank
Full Tube Bed
Rear Axle Moved Forward 8"
Explorer 31 Spline 8.8 Limited Slip Re-geared To 4.88
F250 Shock Towers Out Boarded (Rear).
12" Travel F250 Rear Shocks
Cherokee Leafs, running them backward with one explorer leaf.
Custom Tacoma 5/8ths offset shackles
60" High Lift Jack with Custom Mount
Moss Paint Job
112" Wheelbase with 3" lift
*Wish List*
Rear Selectable Locker
31 Spline 8.8 ChroMos on 5x5.5
Rear 3000lb Winch Mounted Over the Rear Axle
Small Exo Cage (Only Over The Cab)
Axle Wrap Issue
Bend Control Arms (hang down too far)
Finish Center Post For Coil Springs
Rear Brake Line Mounts
8.8 Truss
finish small exo
rock lights
more headlights
front brake line routing
So I know a few you heard about my truck getting totaled in Denver, CO. during my axle re-gear.
Old truck now totaled, as you can see the frame is jacked up:
Well I got a new truck and Ive done a fair amount of work on her and its about time for a build thread.
Here she is stock with my buddy's jeep on 35's next to it:
The truck is a 97 Ranger, 4x4, 4.0L, 154k miles, 5-speed, long bed, manual hubs, and a hydraulic plow for $2500. The truck got sucked in a ditch and was pinned against 2 trees. That's why the body is kinda jacked up. The bumper is pretty messed up too from when they pulled it out.
I think I'll name her Darla... Little Darla now, Big Darla later!
Well I had a Moab, UT trip planned before my truck got totaled and the trip was in 5 days so let operation Moab or bust begin!
It was, and still is, the middle of winter and I had no decent place to work on a truck so I found a decent shop/garage to rent for 25 dollars a day.
My plan was to swap my 4" lift, both axles, and my new 35's before the Moab trip.
Well I wanted to get both trucks in the shop but the beams made it damn near impossible to get the trucks in there. I got the bright idea to buy a rolling jack and swing the trucks in.
Got both trucks in:
Now off with the back axle's, Cindy-lou's (thats the name of the old truck) axle off (picture of my buddy):
I used the 64 inch chevy leafs and the belltech 6400 shackles. Also the new 31 spline explorer 8.8:
Got the axle and leafs mounted:
She sits a little hot rod now:
Now with the front suspension:
The front axles took us the longest from them not easily lining up and no pictures sorry.
We actually got the axles and lift kit swapped!
Off to MOAB we go!
I broke my locking hub on the obstacle behind this picture:
Trail fix:
Well it turns out that I had the wrong locker and there was too large of a gap inside the locker ( between the pins and springs) and the pins sheared the springs and with no pressure against the springs the truck only has 2 wheel drive because the locker wont engage. (powertrax locker and there is a carrier difference between a Dana 35 with ABS and non ABS.) A new locker spacer/locker carrier is on the way!) Me getting towed off the trail:
We had to cut the trip short one day because of my truck being broke, but had a good time non the less!
I also got one fiberglass fender on:
I found out my tire was being cut by my stock fenders so I decided to chop em' right where the silver molding was:
I gave her a lil bath... she looks good:
Thats all ive got for you guys now! More to come when the weather gets nicer.
(I had to axe some of the original pictures so I could edit this first post with the most recent pictures and spec's.)
8500 Lb Superwinch
Chopped Grill
Hood Pins
Warn Premium Hubs
4" Front Stretch
Solid Diff Cover
1 Ton Tie Rod Ends
Painted Dash
CD/IPOD Deck
Aftermarket Seats
Full Tube Bed
Moss Paint Job
*Wish List*
Axle Wrap Issue
8.8 Truss
finish small exo
rock lights
more headlights
Got both trucks in:
Off to MOAB we go!
Trail fix:
