Best starting upgrades for off-roading 1994 Ranger XLT
RangerRyan50
Denver, CO
Ford Ranger XLT
Yes it still runs through the radiator and plumbing it into the existing line was not difficult at all. Attaches at the upper line / upper radiator port with barb fitting adapters. All I had to do was slightly push the OEM hard line over a bit to make room for the rubber lines. No cutting required. Plumbing it was the easiest part of the process. I'll take a pic of how the hoses are hooked up when I go outside.
One question, did you need to add extra trans fluid after installing the cooler? And if so, how much?
Uncle Gump
Token Old Guy
13,458
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You will probably have to add some... the amount will be dependent on how large the cooler is. You will most likely loose some during installation also. So put in the amount you lost then check it like normal and add to the full line.
sgtsandman
Aircraft Fuel Tank Diver
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Any time you add to a system that holds a fluid, there is going to be a need to add more than the OEM spec calls for. It just goes with the territory.
lvwill
143
Las Vegas Nv.
2.3 EcoBoost
2.3 Ecoboost
IMHO the best thing you can do is gears and transmission cooler
