Bent Frame. Extended Radius Arms?
bendy_boi
NW
Mazda B4000 SE
Hey guys, I'm hoping for some advice. I'm not much of an off-road guy, and I don't intend to off-road this truck or lift it, but I figure with the issue I have and what I'm thinking to solve it, getting advice from some 4x4 guys would be very wise.
I have a 1996 4.0L, extended cab, 5-speed, 4x4.
To the point. I have a slightly bent frame rail, it's at the driver's side radius arm bushing mount, it has pulled the driver's side wheel end back 2 inches.
I want to put on extended radius arms, likely at the trans crossmember (because I can't measure with a bent frame) to restore front axle geometry and make the truck alignable.
Can I equip the truck with extended radius arms without lifting it? They tend to change the caster angle since they are supposed to be used with a lift.
SenorNoob
579
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I can't see why not if you can make your own radius arms.
Also, wasn't there a set of (Rancho maybe?) extended arms for stock height?
snoranger
Professional money waster
ASE Certified Tech
13,676
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Pushing the wheel back 2” is not a “slightly bent” frame. That’s a good amount of frame damage. If it is all frame damage and not radius arm or radius arm mount damage... I’d be looking for a new frame.
Junk Collector
Truck of Month
4,827
Rapid City SD
Factory radius arms are fairly easy to bend, I junked a truck that had been rear ended and that collision bent one of them. The bracket on the frame is kinda weak sauce too.
I'd be looking around for a body shop with a frame machine that can straighten it out. Replace the radius arm and bracket too if they look at all suspect.
