- Jun 2, 2012
- 8,374
- canada
- Ford
+1 to what ericbphoto said
But just to clear up the names of things
The rotor is the part that spins and it has coils, also called field coils because they generate a magnetic field, the rotor's fields is what needs to be "excited", which is done by the green wires voltage, key on
The Other Fields are the stator, these are in the case of the alternator, there are 3 field coils and they generate AC voltage as the rotor spins, each of these fields has a set of diodes that convert the AC volts to DC volts.
I generally call the rotor the rotor, and ignore the fact that it has field coils, lol, just less complicated IMO
And I call the stator "3 Field coils" because that also what they are.
The Rotor is what needs to be excited so the 3 field coils(stator) can generate AC volts, this "excitement" comes from green wire first then alternator takes over
Rotor usually gets 7-9 volts "excitement", to produce it's 13-15volts as needed
