djjauntyj
- Feb 28, 2019
- Reaction score
- 0
- Location
- Seattle
- Make / Model
- Ford Ranger
- Automatic
Hey all... recently the passenger rear wheel on my '98 2WD SuperCab had an unfortunate run-in with a curb. The impact destroyed the wheel and bent the axle shaft and brake backing plate slightly. It's a 7.5" LS axle with the bigger 10" brake drums (not 9"). Now, I have all the new parts lined up *except* that backing plate, because of course out of all the possibilities, only the 10" right rear one -- F57Z-2211-A, the one I need -- is the one they discontinued. 9" ones are plentiful, and you can still get the 10" driver's side one, ffs.
So I guess two questions: does anyone have any suggestions for finding one aside from driving to every wrecking yard in Western Washington on the chance there's one I can pull? (which, seeing as how you have to pull an axle shaft to get it off, sounds like a nightmare.)
Or, has anyone had any luck straightening a bent backing plate? FWIW I believe it's bent/warped at the mounting pad where it bolts onto the axle tube flange.
Thanks in advance!
Thanks in advance!
