Axle shaft rubs
Missed leg day
Passenger side axle shaft is rubbing on the driver side drop bracket or front bracket 6 inch old skyjacker lift kit everything is tight it sits level anyone had this happen before?
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Have you checked the radius arm bushings at the frame. Approx. under passenger seat.
Missed leg day
Yeah I did they don't look that bad lol but nothing to make it move that far forward I hope, I will post pictures a little later thing will be the death of me.:annoyed:
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Just to be clear;
Your passenger side axle BEAM is hitting the drivers beam drop bracket [mount]? [drivers beam mount being on passenger side]
Missed leg day
Yeah you got it
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Sounds like something is bent or out of position.
Pics would help for sure (pics of where it's hitting, the d-side beam bracket, and of the radius arms, bushings and mounts).
lvwill
143
Las Vegas Nv.
2.3 EcoBoost
2.3 Ecoboost
I saw 1 picture and I can tell you for sure that the bracket in question is severely pushed back.. it should be bolted and tight to the cross member.
Missed leg day
Ok is that the first pitcure? Bec its all ran down tight!
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I'm sorry, I will not sign in to anywhere in order to see someone else pics. I don't know how you can make google show your pics. You can load them to an alternative pic hosting site OR you can put them into your "pictures and albums" located in your TRS control panel.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Missed leg day
I tried it didn't take the pictures
Missed leg day
Don't worry about it thanks anyways!
