Are auto shift knobs different from 1st Gen rangers and bronco ii??
svtcards
137
Lyman maine
302
3'' front 4''back
So I bought this bronco ii a few weeks and it didn't come with a auto shift knob.I sourced 1 already but it won't work. So the shift lever bronco ii has a white button that needs to be pushed down to put into gear and knob I got appears to have a slide on it. I had a 83 ranger yrs ago if I recall right it had a cable thing sticking up above lever where this knob would work.Are knobs different between the 1st Gen rangers and bronco ii's or am I missing a part that goes on top of lever B4 knob I currently have. Here's a few pics
tw205
Bronco II Rancher.
977
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
I believe the white rod in the shift lever should be above the top edge so when you squeeze the release that lever in the handle pushes down the white rod.
Looks like yours is broken off or pushed in.
svtcards
137
Lyman maine
302
3'' front 4''back
Does anyone have any pics on what it should look like by any chance? And how do I go about fixing it?
tw205
Bronco II Rancher.
977
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
This is what it should look like when it’s all by itself
The white rod will simply pull out. Yours looks to be broken inside the tube. Use some small tool, needle nose pliers, hemostats ( roach clips for the unrefined) to reach in and pull it out. Then go find another unbroken one and put it in.
The rod is simply a floating connection between the handle and lock mechanism.
svtcards
137
Lyman maine
302
3'' front 4''back
This is what it should look like when it’s all by itself View attachment 99031
The white rod will simply pull out. Yours looks to be broken inside the tube. Use some small tool, needle nose pliers, hemostats ( roach clips for the unrefined) to reach in and pull it out. Then go find another unbroken one and put it in. View attachment 99032 The rod is simply a floating connection between the handle and lock mechanism.
That's all it is? No spring inside or anything? Didn't think it stuck out so far.thanx for the pics.Now I need to find 1.
svtcards
137
Lyman maine
302
3'' front 4''back
I wonder how far down the rod is broken inside that's the real question!
tw205
Bronco II Rancher.
977
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
The spring is all maintained at the locking mechanism. The plastic rod pushes against it.
I think all the automatic Rangers and Bronco IIs 83 thru 89 had the same shifter. 90 went to a column shifter. Should be easy to find.
tw205
Bronco II Rancher.
977
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Looks like ( I’m half blind ) if I blow up the pictures, it’s the very end 3/4” segment. May be hard to get ahold of it.
A couple trim nails edged in around it to secure it. Then try and drill a small hole in the top to drive a screw into.
Hope he keeps us updated.
svtcards
137
Lyman maine
302
3'' front 4''back
Looks like ( I’m half blind ) if I blow up the pictures, it’s the very end 3/4” segment. May be hard to get ahold of it. View attachment 99061View attachment 99062
[/QUOTe. Definitely can't get it removed with pliers! Can't get a hold it. I was going to drill into it like u suggested. Will keep u updated on how it goes
