Getting a lot closer, sort of.
Well, I decided to use this 1991 block I had. I was able to make it roller capable, with a twist. In the pic below, there is a pic of a spider. It is one from a 4.3 Chevy turned upside down. It fits perfectly when fitted upside down. And there's my intake shield.
Progressing further, my valve size selection buggered me. I didn't realise there wasn't that much room on the valve to block clearance. So, it bit me on the arse. I'm back into custom piston territory as it stands. Not a major problem. Since I cheated out on the block I guess it's 700 worth of pistons instead of 500. Oh well. Since this little development I am going to use a 5.7 Chevy rod now. Still a couple hundred cheaper. And since the CH will be 1.375 I'm gonna run a Chevy .927 pin. It still gives a 1.8 rod ratio. More cost on the piston, but free on the rods
It will have this to say about the Vulcan block: outside of some nasty casting flash on the underside, this is one of the stronger factory blocks to hone. The "most holy 010" Chevy blocks don't hone as good as this Vulcan. Hardly any dwell on the hone and less than two tenths OOR. I honed it from .030ish over to 3.550 and it went well. Not like honing a 302 or a Mod. Those are like honing a beer can. No, I'm giving the beer can too much credit. Those two are like honing a Solo cup. And I have a torque plate that kind of fits. If I'm bothered to fit it.
A secret from a machinist here regarding torque plates... They're semi useful. The ancient lie has been "it simulates it running/head torqued up." Ok. If the block is so junky from the factory that the block distorts from a dozen or so bolts being torqued to 60 ft-lbs what is 150 psi cranking pressure/ 1000 peak running compression gonna do to it?
Anyway, I digress. The LS rockers look good and geometry kind of well. They pattern as well as the stock crap. Guy at Delta told me they were 1.5, but I'm not sure.
I'm going to re valve job the heads yet again, the indicator lied to me. A couple intakes are not deep enough. And putting in a hard-as-a-whore's-heart exhaust seat.
Time to post pics, more coming soon.
