I won't defend Duralast or Bosch (in this instance), but are you getting ignition misfire?
i WAS getting a misfire. i have no real idea why. but i have a feeling its related to the synchronizer, which im going to replace and i wanted to replace the coil and wires with better stuff. i'll explain what happened in the next paragraph but its kinda pointless since the misfire went away
so i had a misfire in cylinder 2 and i talked to the techs at my work(toyota) and they said to switch my plugs, move the #1 wire to #2 to test the wire and i did that and it stayed in cylinder # 2 so i went to autozone and exchanged the coil and it stayed in #2 so i took it to toyota to have them look at it and they couldnt figure it out. a few days later my dad came home and decided to look at it. he said to exchange the wires, so i did. and the misfire went to cylinder #1. then according to the haynes manual, all my wires are rotated 180degrees. 123 are on the driver side and in the manual are supposed to be on the passenger side. so my dad decided to switch them, i didnt want to, but he did anyways. needless to say, it didnt start. so we moved them back, it look a little bit longer to start and then the misfire went away and hasnt come back. its taken a little long to start a couple times so i think its that synchronizer. but as for the misfire.... im stumped.
