corerftech
- Apr 22, 2021
- 84
- Memphis, TN
- Ford Ranger
On the 1990 2.3 there is a vac line controlling the hot air riser valve from the exhaust manifold and also a vac line to the manifold vac tree.
Having redirected both from a JYD but disassembled I want to make sure I have the order correct.
mom the Air cleaner housing there is a vac stub with two ports.
Is there a specific order to install those lines?
This is the two metal spuds on the air cleaner box on top, need to know if it matters in/out.
There is a logical order as the lines are specific length and visually make sense but if it’s backwards?
is it just a pass through to protect the plastic heat intolerant section from tree to spud from being exposed to the harsh heat near the manifold (a basic rubber line?).
Im trying to wrap head around the numerous areas of vacuum leak that could be occurring and so far I have an evap canevap purge tube and hose ends, valve cover oil vapor line to TB, vac tree, egr red/green, vac accumulator tank, it’s hoses, , FPR vac line, TB to upper manifold, upper to lower manifold, head to manifold, and I think there is a Vac tree to egr line too……
I am so very close to having removed every issue, it’s sickening.
I wanted to register the car today and get it insured and start driving (pending windshield install) but I’d rather resolve the defects (egr code 33) first.
My evap can was missing the big breather plugs and was essentially disconnected on arrival. I have procured the plugs and installed and have the vape line installed from tank to can, and purge from can to TB.
A thought just crossed my mind, is there an order to the evap can lines, I have the vape on the front spud (closest to grille) and the purge on rear (closest to engine). ?????
