lowspeedpursuit
- May 6, 2022
- 151
- DE
- B2300
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 4WD
Noise continues with varying loudness. Worst noises have stabilized to heavy acceleration in 3rd, or decel in gear in 2nd. Here's my thought process: a Zumbrota reman 2.3L 4x4 M5OD is ~$1400 shipped on RockAuto, including $400 core. My junkyard charges $145 for a transmission. So, now I have a mileage-unknown, 2.3L 2wd M5OD out of a '97. Spins freely; some play in the input shaft.
I am going to take both transmissions apart, again. I am going to see if I somehow obviously smoked a bearing in my original, either from installer error or maybe building it too tight and burning it up. Then I'm going to compare all the parts I didn't replace: forks, synchro assemblies, gears, and the cases themselves, to see if anything from my original looks noticeably worse. I'm going to install the 4x4 mainshaft and tailhosing on the '97 case, with whatever parts look best between the two of them. If it works, great. If it doesn't, I set some money aside to buy a reman and send the trans full of worse-looking 2wd parts in as a core, saving myself $200+ in core charges.
