Adventures for coil spacers.
Jsommers
michigan
well my adventures started off when i got tired of the front end sag on my truck. i dont ever tow anything so i figured i could fix this.
so i went to fastenall. out of there millions of fasteners they failed to find any 1 3/8 id washers other than some that were like 8 bucks a piece. so i scrapped the washer lift and moved on
so i went to the ford dealer with the part numbers from the f150 coil seat lift page. i figured that they would be $15 just like the page said. i walked up to the service counter and told him. he told me $80 a piece.:icon_surprised: i about fell backwords. i could buy the skyjacker coils for that.
so thats where i am.
saggy front end and wondering what i should do now.
i dont feel like paying the $200 for the skyjacker coils and the alignment.
so what am i doing wrong any ideas?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Either way you will need an alignment.
Lrpalo
I went with aluminum 2 inch coil spacers. No matter what you do you will need to get it lined up because you camber will be way off and you will roast your tires. Any more than 2" you will not be able to run stock camber bushings.
slow96gt
shelbyville tennessee
f150 coils?? or buy some washers from the internet
The_Dealer
10
Macon, GA
Duh!
fastenall 1 1/2" id 3" od washers, almost 1/4" thick, about 1.27 each...i bought some the other day. i have the part #'s in my rig. ill post em up for u when i go get the reciept
Jsommers
michigan
i know i need an alignment. just looking for the parts to get before that.
the f150 coils i think are too stiff
and i guess ill go back to fastenall tommarrow and ask about more washers.
Jsommers
michigan
thanks everyone for the info tho.
legoms013
09/2013 OTOTM
26
CA
4.0L V6
Grainger Industrial supply has 1-3/8" ID washers.....20 or 25 for $16.
The_Dealer
10
Macon, GA
Duh!
as promised:
fastenal part # 33030
control#140009096
description: USS F/W 1 1/2z
$1.65 (ea.)
hope that helps
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
1-1/4" I.D. washers can be used after a small amount of work with a rat-tail file.
greasemonkey6886
Sulphur Springs, Tx.
Junk yard is a great place to find the F-150 spacers, afterall they don't wear out right? Probably pick up a set for around $20 and won't have to worry about stacking wasers and they look better in my opinion. just my two cents.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Jsommers
michigan
marshall michigan
i google mapped it
higgins lake is about 3 hours away from me
legoms013
09/2013 OTOTM
26
CA
4.0L V6
There is nothing to worry about when stacking washers.
Jsommers
michigan
lol now that i have my washers i can find the time to put them in
