adjust valve train hot or cold?
adjust valves hot or cold
  • hot
  • cold
Results are only viewable after voting.
stamina
34
Wilmington, NC
4” suspension
265/75/r16
built her in a storage unit
i am going to adjust my valves soon and i’m wanting to know if i should do it while the engine is warm or when the engine is completely cool. i see LOTS of different things on the internet.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,711
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
When did valve lash adjustments, it was a different manufacturer and engine. But the service manual said to do it cold.
ericbphoto
Overlander in development
16,667
Wellford, SC
3.0L
6"
I always did it cold on my Mercedes.
But that's probably because it never otemperature to me that I should be concerned about the temerature and I don't think I ever did it in the winter.
pjtoledo
2,989
Toledo Ohio
Fords
3.0 2.3
being an 'ol fart I remember when the manuals gave measurements for both hot and cold.
so you can do it either way if you have the correct numbers.
fyi, adjusting valves on a running engine usually resulted in trashed feeler gauges. and lots of smoke
Blmpkn
Toilet enthusiast
6,372
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I've always done it cold on small engines.
gaz
671
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
To make the hydraulic lifter adjustment the Chilton's Manual says to perform the procedure with engine COLD.
