BillupsOMally
- Mar 31, 2009
- 0
- Ontario, Canada.
- Ford
- Engine Size
- 4.0
So I bolted my A4LD transmission back onto the 4.0L motor that came out of a 1991 Explorer and ran into problems.
I bolted the torque converter to the motor before lifting the transmission into place, supporting it with jacks and jackstands and the slid it into place. The transmission slid into place quite easily right down to the last 3/16", maybe a little more/less, then I drew it in the rest of the way using the mounting bolts.
Now the problem is that the engine won't turn over (wrench on crank pulley), if I crack the nuts loose and back the tranny off just slightly it turns over with an acceptable amount of effort.
I read in a Haynes manual that the torque converter should be installed in the transmission before putting it in. Is this done for a reason (ie. might it solve my "seized" tranny issue), or is it just to ease installation.
Thanks in advance for any input or suggestions.
