- Apr 17, 2023
- Reaction score
- 15
- Location
- USA
- Make / Model
- Ford Ranger
- Engine Type
- 4.0 V6
- Manual
- 2WD / 4WD
- 4WD
Hello, everyone. I'm new here, wondering if you can help me out with some truck troubles.
I have a 2005 4x4 manual Ranger with the 4.0 V6 SOHC (166K miles). It seems to run all right but has had a P0172 code for the longest time. OBDII data shows that the long term fuel trim is extremely rich in bank 1 (-25%), and even bank 2 has about -4%. It smells strongly of gas around the truck. Just a few days ago it sent out a P0420 code (cat), and I'm wondering if the rich condition is damaging the cat.
Upstream O2 sensors (Bosch), alternator, PCV valve, air filter, MAF sensor, and a bunch of EVAP components have been replaced. Cleaned the throttle body and IAC. The truck's wiring is pretty bad (previous owners did janky stuff), so there could still be something connected incorrectly.
My mechanic couldn't figure it out. His thought was either a leaking fuel injector or a timing chain problem. Compression test was normal. Balance power test showed cylinder 2 was low. No vacuum leaks, no exhaust restriction. I know that the SOHC is infamous for timing chain issues. I tried fuel injector cleaner additives but it hasn't made a noticeable difference.
I'm thinking about replacing/cleaning all the injectors and swapping the timing chain tensioners. I've never removed an intake manifold before so this is a big job for me. Do you think this would be worthwhile to try? Or do you have another idea?
Thanks for any input you might be able to provide.
