A/C quits under heavy acceleration.
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
2005 E-150 Cargo van. AC didn't work when I got it. Put it in the shop about a year ago. They got it blowing cold with no issues. I leave it running when making deliveries to keep it cool inside. Here lately, I've noticed it doesn't get as cold as it used to, when idling and blowing hot air under heavy acceleration, like passing or giving it gas to go up a grade. First guess is vacuum leak, but I wanted to run it by TRS before I take it back to the shop.
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Afaik its normal for ac to be bypassed under wot.
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
I agree with @alwaysFlOoReD about the WOT, but the idling not cooling as well I think you might have an issue. It could just be your mind playing tricks on you about it. But to be sure put a thermometer in the vents and note what the temp is driving and at idle. You should have about a 5-8* difference because idling doesn't get the air flow like driving does. IIRC, AC vent temps are usually around 55-60* driving. You may just need to have the AC serviced or there may be a small leak. Also, MAX AC recirculates the air in the vehicle, so if its hot to begin with, it will take longer to cool down.
If you have a black dashboard the heat transfer can have an effect on the cooling abilities as well. Sunshades/window screens can help with this A LOT. Living in FL I'm sure you know this already though.
fastpakr
2,842
Roanoke, VA
A/C vent temp going up during WOT does make sense. But if you're actually losing airflow from the vents then that's a separate and possibly additional issue involving vacuum to the vent selection system.
avid
26
Omaha, NE
XLT 4.0 OHV 4wd
The temperature variable may be a separate issue from the blowing. I had the blowing issue and it's a fairly common problem it seems.
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
Never noticed the WOT issue until this week. It was also hotter than ass outside this week. @fastpakr, I'm not losing air flow, just temp increase. Maybe it's just me being finicky. I'll keep my eye on it. thanks for all the responses. @avid I'll skim that thread for any leads on my situation, thanks for that link.
fastpakr
2,842
Roanoke, VA
So 'quits blowing altogether' isn't what you meant?
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
sorry, quits blowing COLD altogether, is what I meant. Sorry sir.
EDIT: I fixed my vocabulary in the first post
Junk Collector
Truck of Month
4,851
Rapid City SD
Please speak in upper 49 instead of lower 1. 🤡 😄 :thefinger:
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
:flipoff:
Brain to keyboard connection is never very strong. What I have in my head isn't what always gets typed.
holyford86
Some guy with a problem
633
Plattsburgh, NY
many
33x12.50R15
I've seen the vacuum canister fail on those, they're a pain in the ass to get to and replace, I've done two and wouldn't like to do another. Usually what happens is the mode selector will default to defrost because there isn't enough vacuum though, It'll still blow cold air, just not where you wanted it.
Ranger850
4,696
Tallahassee Florida
Stock 2"
Stock
Got the go ahead from my Boss to put it back in the shop. Luckily it's across the street from my work
