9inch bronco coil lift need steering ideas
whoischriscates
Van Buren Twp
im going to be doing a sas on my 88 ranger near spring running d44 front and 8.8 rear. planning on using 78-79 bronco 9 inch coils but i have no idea what do about the steering. any ideas or links would be great. thanks
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
What do you mean you have no idea what to do about the steering? I'm assuming its a narrowed dana 44?
I'm going to use a Y-link setup with chevy 1-ton TRE's (Tie rod ends)
I'm going to be honest with you. If you can't figure out the steering then I don't think this is something you should do. Before jumping into this I would do a lot more research.
legoms013
09/2013 OTOTM
26
CA
4.0L V6
4 things to know. Take these and google them.
Crossover steering
t-link steering
heims
chevy tie rod ends
With that you should be able to figure it out from there :icon_thumby:
whoischriscates
Van Buren Twp
im running full size axles, i have kind of looked into heim and the 1ton chevy tie rod ends. i just dont know what would be the strongest and best for my application. i'm building a mud truck and i just want everything to hold up to some abuse. i've lifted trucks before but never did an axle swap or anything this big so i know trying to reuse the stock tie rod setup probably wouldnt be a good idea.
bobbywalter
TRS Technical Staff
2,664
woodhaven mi
FORD mostly
BIGGER
sawzall?
go over to parts galore or taylor auto salvage and get some k truck tie links, mod them to work.
