99 stereo in 97
Alex FX4
will the wiring on a 99 stereo be the same as a 97 stereo. the double din stereo that is.
superds
80
ND
Ford Bronco II
2" body. 1.5" coil spring spacers/rear block
I'm fairly certain it would be the same electical connector. I've had several Fords from 89-99 and if I recall correctly they've all had the same connectors.
Ranger Sport Honduras
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
Fortune Favors the Brave
i think its the same too. best option is to try it.
97RangerXLT
TRS 25th Anniversary
4,012
Fishers, IN
2"
31"
Nope, it is not. the harness is different. you can get an adapter for it tho.
I have a cd/tape combo from a 99 that I am going to put in my 97 Ranger, and I found this out the hard way. everything else is the same, it even is the same style as the 97, just the connector is different.
AJ
97RangerXLT
4,012
Fishers, IN
2"
31"
superds
80
ND
Ford Bronco II
AJ
That really surprises me, I totally thought they were the same. What year did they change? 1998 or 1999?
superds
80
ND
Ford Bronco II
Zoom Zoom
197
Honduras
Mitsubishi/Ford
3.0/2.3
from 99 to 03 its the same then. i installed my 99 on my mom's 03 that had the basic radio and works fine.
i only had to do the wiring for the rear speakers.
97RangerXLT
4,012
Fishers, IN
2"
31"
yeah, they changed again in 2004-5.
AJ
