99+ m5r2 starter questions
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
Quick question. Im using the 99+ m5odr2 trans from a 4.2 f150 in my ranger. I have the clutch and flywheel from a 95 f150.
what starter do I use? The one for the 99 f150. Or the one for the 95?
Thanks.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Did you use a 95 flywheel and clutch for a 150?
85_Ranger4x4
17,866
SW Iowa
tis what I purchased. But no workie. Grinds like hell.
What engine separator plate did you use?
The "correct" one has a slightly bigger hole so the starter won't fully index into the plate if the plate isn't right.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Yeah.....for sure the plate has to be for a v8 manual....92to98
RangerFabWorks
715
302
Clutch and flywheel are from a 95 f150. Separator plate is from some ford. But the hole is big enough.
only way the starter doesn’t grind to hell is if I shim the hell out of it. Talking almost half an inch
so either I somehow got an automatic starter. Or somethings wacky
RangerFabWorks
715
302
Ok. The 03 starter doesn’t work at all. We can put that to rest. Gonna guess I got a bad starter at work. So I’ll order one from elsewhere and report back.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
The hole is one thing..
...the indexing is the other ...
There is a 3/8 offset potential on nose cones...but a 92 to 96 150 starter 35/36/37 style. 37 iirc fits it.
Summit has the right block plates
RangerFabWorks
715
302
Turned out to be a bad starter. Got a motorcraft one and it fit perfect and sounds good.
SpunkyPrep
Middle of North Carolina
Ford/Ranger
5.8
2" drop beams
To have no pursuit is to have no purpose.
Huh. Bad starter?
I've got a 351w from a 1997 F250 mated to a M5R2 out of a, i believe, 1996 F150.
Flywheel should be same as motor. ended up using a shifter and shifter stub out of a 1998 F150, M5R1 trans. Works, so not knocking it.
Problem we're having is starters. There is a separator plate between bell housing and engine block, and the guy at the shop ended up using an additional shim-type spacer between the starter and the housing. I should have taken pictures of the damage to the starter gear when i was there, but i forgot. This is apparently the second starter they've gone through. Is the most likely option that the starters were just bad? They got them from O`Riley's, and i can't imagine two are bad brand new out of the box. It seems to me that the starter pinion isn't fully disengaging from the flywheel after cranking.
Transmission guy swears it can't possibly be that the pinion on the starter is staying interfaced with the flywheel due to not enough spacer and that the starters themselves had to be faulty, but that doesn't jive with what i saw.
Trust the dude with 25+ yrs experience rebuilding and dealing with transmission issues as a profession, or contradict his assessment based on my observations and intuition based on apparent damage on the pinion gear?
Included picture looks exactly like the damage i witnessed at the shop.
Sorry to zombie a post, but the issue seemed similar to my situation and i didn't want to arbitrarily create a new thread when it already is discussed elsewhere.
