99 2.5L bad alternator?
Rainmaker
Minnesota
2.5l
I pulled off to get gas last night about 150 miles into a 200 mile drive and had very sudden electrical loss. Battery light came on, radio turned off, lights dimmed. I was able to get to the station and after sitting a few minutes I could start again but severely under powered and only lasts about 5 minutes or so. The only symptom I noticed was about 75 miles into this drive the lights seemed to brighten up a bit. I assumed my eyes were playing tricks.
Sounds like an alternator but I'm worried about a larger electrical problem. Anybody have any thoughts?
Seriously looking forward to working on this thing outside in 11°F...
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,501
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Time to get out the voltmeter... engine idling battery voltage should be right around 14 volts if the alternator is working.
Rainmaker
Minnesota
2.5l
I can do that. If voltage measures fine what might be your next thing to check?
Thanks!
tomw
46
lima bean
vertical and above ground
Definitely check that the battery post terminals are tight and corrosion free. A loose terminal can cause weird failures as the battery comes and goes from the charging/power system. Grab and see if you can twist, and if so, tighten.
tom
