onlyme
- Jul 8, 2010
- 2
- Oklahoma
- Ford
- Engine Size
- 2.5
I been searching the internet for an answer, but still a bit complexed. My 98 Ranger 2.5 has an issue, P0122, high idle, no other codes thrown. I bought this truck with this issue, I did however put a new TPS sensor on the truck, but the idle remains the same. I did test the TPS sensor and connector with a multimeter to make sure it was receiving voltage and ground, and I did the TPS sweep test with the throttle also. There was no spikes or dead spots, and the idle was about .96-.97 volts to 4.5 volts wide open.
I know however that the throttle plate screw was messed with, which I am not sure how to reset correctly. I believe that may be what's causing the issue, I know the truck is suppose to idle at like 750 rpm, but unfortunately my truck does not have a tachometer to read the rpm. Right now when it starts it idles so high it sounds like your cruising down the freeway when in neutral (it's a manual)
Is there a correct way to rest the throttle plate screw to the factory setting?
